I've a Pearson 89' 39-2 & I am so tired of water in the bilge, which should be dry. I have confirmed it is ftesh water. I've replaced several connections (it is the original grey flex tubing and connectors) and in just a month or ywo it's leaking again. I can turn off the pressure pump after every use and it stays dry. So, I am considering replacing the system as a whole with clear reinforced poly line with doubled stainless hose clamps & brass fittings.
Any one pulled and replaced their fresh water system? What troubles did you experoence with pulling the new line? Has the new sustem been leak tight?
I really would like a dry bilge before we retire & head south.
dabishop
dabishop
