Just commissioned the domestic water system for Spring 2 weeks ago. I had drained the system for winterizing back in November, with some AF through the cold side to set the pump and a line that is more difficult to drain. Some AF entered the water heater, but it was drained again.
Yesterday, water from the hot side is effervescent, to the point of a dry-ice-style mist emitting momentarily from the top of the cup into which I'm pouring water. Also, it is tinged a bit purplish-gray. The AF I used was pink, and there has been several gallons of water run through it since.
The cold side is clear and perfect.
I had installed a new HTP SuperStor 6g water heater last Spring, so I'd think there is no issue there.
The only thing in the system other than water is a little chlorine bleach. I cleaned the tanks and shocked the system at commissioning, and then refilled the tanks. There may be a little more bleach percentage in the heater than is now in the tanks, but it can't be much. I only put < an ounce in there with about 15 gal water to do the shock.
Any ideas? What is causing the fizz and coloring on the hot side?
