This spring I'm interested in plumbing the head in my 387 to use fresh water vs. lake water... (the lake water in the inlet hose gets pretty rank during the week, so the first flushes every weekend are NASTY) I've heard there are two ways; dedicate my rear water tank to the head.. plumb it in directly. Or tap into the water line that goes to the sink. My questions are two: which way is preferred? Can you run pressurized water to the head? If not, that means redirecting one (rear) water tank to the head is the way to go. Do I need an antisyphon value or checkvalve? Assuming a dedicated tank.. how does a person gain access to run the flex line from the tank to the bathroom? Under the floorboards I found solid white panels of fiberglass... can I cut through? Hopefully someone has done this before me and can give me some steering.... thanks in advance.
