Fresh Water Pumps
8
hunter 356 Deale Maryland
My pump on my 2003 Hunter 356 is leaking but still working. It is Parmax Auto Water 40 psi pump with a serieal number of 31595. My
Nov 6, 2006
10,257
The pump can be rebuilt or this site has new ones for replacement:
http://shop.hunterowners.com/prod.php?16665
EDIT: Lots of times, the case flanges will work loose and simply tightening the case screws will stop the leak.. also, the fittings can get loose and it looks like the pump is leaking when it is actually dripping from a connection.. Look carefully and tighten carefully anything that ya find loose..
