Fresh water hose connections
Rick D
Jun 14, 2008
7,208
Are You Referring To The Deck Fill?
nm
Rick D
Jun 14, 2008
7,208
Or, if you are referring to the internal fresh water plumbing, then the folks here at the Chandlery can probably help. See the "Store" tab on top and go to the Hunter Parts section and look for a place to send an inquiry. Otherwise, someone on the forum can likely supply an answer. Good luck!
