P
Paul
Hi PeggyI know you not big on “fresh water flush” due to the possibility of siphoning back into the fresh water holding tanks and in general heads aren’t designed to be hooked into pressured water, but necessity is the mother-of-invention. The water where I dock is simply horrible mainly because of the sewage treatment plant up the bay. Anyway, I think I’ve come up with something that would make most boaters smile, since they can make the unit themselves, can’t siphon back into the fresh water holding tanks and it nullifies the pressure of the fresh water system. I have had a unit on my sail boat for two years now serving 2 heads and have given the D-I-Y instructions to 3 other critical boaters who are quite happy with the unit, but before I let the world know how to do it I’d like your thoughts. Basically, it utilizes a small anti-spill reservoir tank. I simply tee’d off the boats pressure line through a shut-off valve, through an anti siphon valve, into the top of a small reservoir, thus eliminating the water pressure and chance of back flow. I mounted the reservoir higher that the head and put in a check vlave to eliminate any chance of water from the head flowing up hill into the reservoir and cut into the head supply line. The unpressurized water in the reservoir is moved only by the heads pump and a little help from gravity as you flush, while the water in the reservoir is replaced by your pressurized fresh water system. It’s that simple, doesn’t leak even in the worst of weather, and eliminates the problems associated with salt water. I did put a 2 way valve on the thru hull line just incase I needed to flush with salt water.
