I have questions about filling the fresh water tank on our Hunter. The previous owner said that he filled it from the access plug under the aft bunk. The boat has this fitting on the starboard side of the cockpit wall (see photo). If I attach a hose to it and attempt to fill, no water flows into the tank.
I have removed the fitting and tested it, water does flow from the outside to the inside side of the fitting.
Any thoughts on the purpose and use of this fitting?
Is there a check valve that is preventing water from enter the system. Secondly, shouldn't this fitting have a protective cap on it to prevent salt water, etc from entering the system since I have proven that water can flow inward?
Bob
Bob
