Fresh air?
120
None now boatless Mobile
I have a 23.5 hunter and was wondering how do I get fresh air in the cabin while under sail?
I have a toddler that will take a nap below and want to ensure she gets proper ventilation, we do live in lower Alabama after all. I thought about proping open the forward hatch but feel the jib will get hung up on it. Any suggestions?
Nov 6, 2009
353
Hunter 37 FL
I replaced our dorade vents with these minivents from SBO store.
http://shop.hunterowners.com/prod.php?17329/MiniVent+1000
Jun 28, 2011
120
Those are interesting but I dont think I have anywhere to mount them on a 23.5.
Jun 6, 2006
6,990
Try placing a board along the front edge of the forward hatch to block it open. Close all the other hatches except the companyonway. The doger acts like a vacume when going to windward and like a scoop when doing down wind. Be sure to secure the wood block so it does not fall into the Vee birth or overboard.
Kermit
Jul 31, 2010
5,722
I feel your pain on this one. Our 23 came with a solar vent installed in the forward hatch. About all it seems to do is keep us awake at night and then finally winds down just before the sun comes up. Then the sun comes up and starts it back again.
We sail with the hatch closed for the very same reason you do. We now have a 12V fan that came from West Marine that works pretty well. You might want to check into one.
Wish I had more ideas for you.
Kermit
May 25, 2004
978
Catalina Capri 14.2 1670 Rochester, MN
As long as there is no spray, I sail my 260 with the forward hatch open all the time. Only occasionally do the jib sheets hang up.
The fractional rig of our boat means the jib is rather small and the clew is well off the deck. From the photos I see, the 23.5 is similar. Might be a bit longer on the jib foot, but the sheets should stay free of the hatch if you handle them well.
Just before the tack, take the excessive slack out of the windward sheet. As you go through the wind, pull in on the lee sheet and hold it until the jib back winds. This will bring your bow through the wind faster and when your release the sheet, the wind will do the work and pop the jib across with little excessive sheet slack and minimum winch work.
Ed H
Sep 15, 2010
244
Hunter 33_77-83 Regent Point Marina, Virginia
How about a stainless steel tubing frame?
Catalina 30 Mandeville, La.
I was in the same boat ( pun intended) several years back when my kids were toddlers. We would just open the forward hatch all the way and the companionway. The air flow was good enough to keep it from getting too hot below. Being in New Orleans, we typically would avoid the hottest part of the day and sail in late afternoon or at night.
