John Van Wagoner
Hey 410 owners Carol, Chris, John, and others: do you guys worry about your diesel engine getting enough fresh air to run effectively? Every other boat I have owned has had 3" or 4" duct into the engine compartment from vents on deck to bring in enough fresh air. The engine on the 410 is pretty well sealed, especially if all the cockpit and aft lockers are sealed up with gaskets to make them waterproof. Right now I guess enough air comes down the channel under the aft bunk from the aft lockers because there are gaps between the locker lids and the locker tops. What do you think? Is it worth adding vents on the cockpit combing and running some duct into the engine compartment?thanks for your advice,John Van Wagoner
