After noticing water in the bilge of our new boat I tracked it back to a section of ununsulated coper pipe comming through a bulkhead from the freezer. Which was iced up and melting each time the compressor stopped. It was icing up near the foam insulation. Thinking I would solve the problem by adding another .5 meter of foam insulation to the copper pipe I have found the icing has moved to the next section of uninsulated pipe which is about .4 meter from the compressor. If I cover the remaining pipe with foam will it have adverse effects on the operation of the compressor. Any suggestions. Al.
