Freezer compartment
Fred
Sep 27, 2008
517
Catalina 28 mkii 745 Ottawa, Ontario, CA
After one season with my H33.5 we would dearly love to have a freezer compartment in the cooler box. From what I can tell the (rather cavernous) cooler box is fitted with a "holding plate evaporator". I suspect that this component was original equipment (from pictures I see on the internet this might be a Vitrifrigo AC10GR-VFA). The PO recently installed a BD50F Danfoss 12v compressor and a CAREL digital thermostat retrofit kit. The temperature probe is mounted on the evaporator and the system appears to cycle between 0 and -4 degrees C.
I was wondering if I could build an insulated box (i.e. pink foam insulation) around the holding plate to serve as a freezer compartment and run the system at around -18 degrees C (0 deg F). I would leave the top of the "freezer" box open so that cold air would spill over into the rest of the cooler to keep other items cold.
Has anyone tried this before.
May 24, 2004
7,235
CC 30 South Florida
Have not tried it but two related things I would be concerned about, 1) power consumption increase by lowering the thermostat to -18C. 2) is the insulation of the cooler box adequate. I don't know that enough cold air would spill out of the insulated box to keep the other areas of the cooler adequately cold. Just consider instead an open on top metal box that would hold the freezing air and allow spillage but at the same time would radiate cold air with temperature graduated by proximity or distance from the box. Perhaps building some rough test boxes and seeing how each may perform could help make a decision before crafting a final box to be permanently installed. For me the power consumption adequacy issue would define whether to move forward with the project or not. Hope you succeed, let us know.
Jun 21, 2004
3,225
Beneteau 343 Slidell, LA
I had a Norcold fridge only on my 33.5 that eventually died. Installed an Adler Barbour unit that included a freezer compartment. I insulated the ice box on top and sides with foam panels on which I bonded white Formica. Pumped in expanding foam behind the panels and sealed the seams with boat life caulk. Worked out well and looked decent. The OEM box is huge and too much volume to keep cool, not to mention that it shares a common wall with the engine compartment.
