After one season with my H33.5 we would dearly love to have a freezer compartment in the cooler box. From what I can tell the (rather cavernous) cooler box is fitted with a "holding plate evaporator". I suspect that this component was original equipment (from pictures I see on the internet this might be a Vitrifrigo AC10GR-VFA). The PO recently installed a BD50F Danfoss 12v compressor and a CAREL digital thermostat retrofit kit. The temperature probe is mounted on the evaporator and the system appears to cycle between 0 and -4 degrees C.
I was wondering if I could build an insulated box (i.e. pink foam insulation) around the holding plate to serve as a freezer compartment and run the system at around -18 degrees C (0 deg F). I would leave the top of the "freezer" box open so that cold air would spill over into the rest of the cooler to keep other items cold.
Has anyone tried this before.
