try Aerokroil
Hi,Try Aerokroil from Kano. You can order direct from Kano Laboratories,at least you could at one time, at (615)833-4101.If that doesn't work you need to either cut the nuts with a nut cutter(preferred), or use heat. If you go with heat, first be very carefull of fire. Repeat, be very carefull of fire. Have a couple of extinguishers handy. Try a heat gun first, not a hair dryer. Then try a mini butane torch if the heat gun doesn't work. If you use a torch make sure all oil, fuel, and anything else that will burn is gone from the engine room! Rags, ect... If you used oil on the nuts before make sure you clean off the oil as best you can before adding heat! If you can't find a nut cutter and don't want to use heat (I don't blame you), you can always do it the old fashion way with a chisel and hammer.Good Luck, Jay
