Possible damage
If you can't find any manufacturer information on it, I'd leave it spin free. The reason being that if something either hits that prop and causes it to rotate while engaged or if you actually moved fast enough for the water to do so it could cause damage to the engine, depending on the engine type. Basically, with it in reverse, if the prop spins from water pressure or something hitting it, this would cause the drive shaft and the crank shaft to spin in the wrong direction. This brings the pistons up at the wrong time, smacking into things like open valves, etc.It would be like taking your car, putting it in reverse, then dragging it forward. This would be the fact with four stroke and probably diesel engines. I'm not so certain about the inner workings of a two stroke. Of course most two strokes are on transome mount swing arms, like mine, and come up out of the water. Just something to concider.Best bet, call the manufacturer and see what they say is best.Josh
