Jim WIllis
1. NEW HIGH RESIN SUPERWAX. OK you thought it was too good to be true, something that you could wipe on in one or two coats and get a close to LPU shine Took an hour or so and waterproof within minutes. Lasts up to a year and a wax too! Can even use on metal!Trouble is you had to follow the instructions and my instructions were far from clear.Well we fixed that. and now we have improved the formula too.Our new HIGH RESIN version is virtually solvent free (traces of solvent of cleaner residue can cause blooming and dulling with water). Yet, this version is not sticky. It covers a greater area. Same price, at least for now and now being shipped with all our kits.I recommend an undercoat of Silkenseal, especially on porous gelcoat and one or two coats of the superwax. You can put a hose on this within 15-30 minutes. We have done the tests! - and the surface is more durable too.2. NON_SKID SEALANTFREE samples of our new Superwax version will be provided with shipment of our new NON-SKID SEALANT KITS ready for shipment by the end of this week. You can already see the results of this products on www.IslandGirlProducts.com. Look on "products" page and click on non-skid sealant. This sealant has more body than the samples mailed out last fall/winter and has a silky, high grip texture. It does not make the non-skid appear "varnished" .3. SUPERGLAZEWe also have another new product coming shortly for dull and chalky paint too! This one is wax free and heat-resistant and can be used on plastics - makes surface of cowl vents like new. We are still determining a good name for this "SUPERGLAZE". Thanks for your patience and your feedback. Jim Willis
