- Jul 24, 2006
- 628
hi all, just finalized a bid for a used diesel. The engine is clean and intact. It has a problem i thought i would bounce off you all. It is reported to be hard starting. The po said it never starts without releasing the compression. He also says that it turns over slow and was thinking about using a "SUPER" diesel battery to see if that helped but just replaced it with new yanmar. I don't know much about diesels. I will check it out-compression, have injectors tested/cleaned, change oil and filters, etc. Was just wondering if someone might know what the problem might be. He said that once the motor is warmed up it starts better. he even added a manifold heater to help it some. Once the motor is running it runs great-he says.
thanks, Patrick
thanks, Patrick
