Found the leaks
Mark
Recently I put a post on regarding a leak in the bow of our new 260 water balast. Romoval of the plate in the bow of the yacht has revealed tow things. The drain from the anchor locker leaks. The filler hose for the water tank had a very large hole in it most likely done when the through hull holes were drilled. Regards
Bill O'Donovan
Axiom
All of which proves the axiom, Try to avoid drilling holes in the boat.
