Foul Weather Gear Stinks
Saturday I was sailing Sonars on the North Fork of the St Lucie River. To be kind the water is less than pristine. It was a little windy and we took spray over the bow a number of times. Actually quite a bit. It was raining so I hoped the river water would wash off my foulies. Not. They were in my car to dry and Monday I noticed the car stank. So I rinsed it with a hose and laid it over a garbage can in the garage to dry. Now the garage stinks. It's like a Seinfeld episode. What can I use to de-stinktify the jacket? All my other gear went in the washing machine - and so far no complaints from the blonde.
Thanks, I wasn't sure if that would ruin the jacket.
It shouldn't. That's why I suggested the gentle cycle. If the jacket is nearing its end of life, sometimes the waterproof/breathable coating will start to peel off. However, that was about to happen anyway. The Hollidays are coming and your wife needed gift ideas. ;)
Turn it inside out to dry it will dry faster.
I'll tell Santa I need a lighter weight jacket here in Florida too.
Dec 2, 1997
9,011
- - LIttle Rock
Before washing, soak the foulies overnight in cold water to which you've added a quart of PureAyre PureAyre (a gallon of the "household" version is about $30 from Amazon). My dad spent his last 3 years in a nursing home...I brought his laundry home to do it because my machines were a lot kinder to it, plus I didn't lose any of it. That last year I was bringing a load home at least twice a wekk, and every load needed soaking in PureAyre...I was ordering gallons of it by the case. It worked! And if it de-stinkified HIS laundry, it definitely will on your foulies. I'd hang to dry in the sunshine and fresh air.
--Peggie
Since I'm going to be sailing on the St Lucie River regularly I'd better order a bunch.
Mar 26, 2011
3,948
Corsair F-24 MK I Deale, MD
Or treat the inside with a anti-microbial/bio-stat, like BAC or one the generic Microban products. Instead of treating odor... prevent it. Even the inside of my drysuit stays fresh. Boots too.
We keep a couple of spray bottles handy. Also an effective hand sanitizer.
Getting things dry is also important. Either take them home or really spread them out if left aboard.
I found links to those products so I'll give them a try. Sounds like a good idea to keep some Microban handy for Covid protection too.
Car smells better but garage reeks! I don't ever want to end up in that river!
Mar 26, 2011
3,948
A cheap source of BAC is Wet-and-Forget.
Looks like there will be little relief as a little research points the St Lucie River issues are tied to the Lake Okeechobee problems and the dumping of excessive waters into the St Lucie River.
I haven’t been here long enough to judge but all the politicians talk about it, brag on the funding for it and I’m not sure they know what to do. When I’ve been to the lake there’s a lot of construction equipment working but I don’t know what they are doing. I’ve read they want to crest a reservoir on the South end of the lake. Supposedly that would limit the discharge into the St. Lucie and the West river I’m not even going to try to spell. The lake is a reservoir anyway so I don’t get it. I wonder why they can’t discharge the lake into the Everglades? Marshes can filter water - yes?
6,432
Catalina 320 Barnegat, NJ
Simple problem? I doubt it. Lake Okeechobee is a gigantic sump in the middle of the state that naturally drained into the everglades. The Everglades were naturally a stagnant sump of brackish water that eventually seeped into Florida Bay. The lake did not historically drain into the Caloosahatchee (to the west) or the St. Lucie Rivers (to the east) until canals were dug to create a continuous waterway across the state, and more importantly in the past, to divert water from draining into the everglades so that agricultural land could be created to the south of Lake Okeechobee.
So now the controversy is how do you drain Lake Okeechobee without re-claiming natural everglades from the farmland that was created? The river drainage is obviously causing environmental problems, but there is a lot of political pressure against re-claiming agricultural land.
Their solutions seem to be an effort to create water storage uphill to the north (Kissimmee River basin that naturally flows into Lake Okeechobee) . That might slow down water flow but it obviously can't stop it. They are also trying to obtain locations to the south of the lake where water can be diverted without re-claiming so much farm land. The canals that connect the Caloosahatchee and St Lucie Rivers would need to be restricted to reduce direct flow into the rivers, but those drains have been opened for years and it would be difficult politically to close them up now.
Draining into the Everglades is the natural and best solution, but they have that (not so) small matter of all that southern agricultural land that they need to either avoid or re-claim. That's the difficulty.
I have found regular old pinesol to be very good at cutting through mildew and mold stink.
I add a cup to my laundry anytime I find an old wet something that has sat around a while.
I also washed scrubbed and rinced my cockpit cover and bimi with a pinesol solution... the efluent washed down the driveway and I was pleasantly surprised to discover that the fire ant nests at the end of the driveway all died (or move away). So that is now my "green" ant killing formula. A cup of pinesol in a gallon of hot water... dump on ant hill. Works like a charm. And the ant hills don't stink now....:biggrin:
  • Ha
