I was leaving my mooring when my mooring line got caught in the prop. The engine shut off with while in forward gear and is stuck in that position. I had no choice but to go into the drink (cold drink 50 - 60 deg) to try to remove the line, but it was wrapped pretty tight on the shaft. I didn't have a wet suit, so I cut the lines from the mooring ball to relieve any stress on the shaft. My plan is to go back with the proper gear to remove the line from the shaft. My question is, after I free up the shaft / Prop, how do I get the gear back to neutral so I can start the engine? Did I damage the transmission? Can / should I start it in the engine in forward gear?
