D.E. Newton
Anybody know how to replace bulbs in 1973 era Catalina 27. they are the recessed kind, stock issue, with two screws outside with a cylinder containing bulb assembly. I wasn't sure if bulb was replaced inside or outside, so I started with two screws outside. They, of course, were deceptively corroded; they looked fine until you applied a little pressure and then they crumbled into greenish fragments. I just want to replace bulbs.
