forward-only outboard??
Richard
Greetings, I have a chance to buy a Nissan 3.5 outboard and a dinghy. The small engine is designed to ONLY go forward; no nuetral, no reverse. The entire unit spins 360 degrees to slow/reverse. Who has used these? Is this an OK design? While I'm at it the dinghy is an 8.6 Zodiac made for West Marine, roll-up floor, PVC. Both items were new in 2000. I've linked the boat I plan to use the dinghy to access the boat on a mooring. Richard
Tom
Nissan 3.5, I have one
I have a forward only 3.5hp and it works fine on my 10ft dingy. Don't expect to plane but for getting around it works fine. Tom
Feb 10, 2004
4,184
Hunter 40.5 Warwick, RI
I have used this type of outboard
I prefer to have a neutral. For dinghy service I have never wished for reverse, but neutral is very convienent. However, if you have a good deal available, I would probably take it. The outboard will be quite workable if it starts quickly and runs at speed when cold-started without problems. It should do this. I have the Nissan 3.5B with a neutral and I have found the engine to be very reliable. BTW, the small Honda 4-cycle has a centrifugal clutch that is really neat. But it is much more money. Regarding the Zodiac- I have a 1997 FastRoller 285 which is about the same size as the one you are looking at. I have had two seams open up and I have a slow leak that I am having trouble finding. I have repaired the seams and I am looking for the leak now. My last dinghy was an Achilles and after 20 years it was tired but never had seam or leak problems. I guess I would not buy another Zodiac based only on my personal experience. But they are very popular and maybe I just have bad luck.
Jun 3, 2004
9
- - St. Thomas, USVI
PVC Dinghy
I personally would avoid a PVC dinghy by Zodiac. I had one and while it was under warranty it was in the repair shop as much as it was out because the seams kept opening. When the warranty was up I donated it,took a tax deduction and bought a dinghy made of hypalon as was my previous Achilles that never gave me a bit of trouble. Not having a reverse or neutral on an engine is an inconvenience but not a necessity.
jim
outboard with no neutral
is a pain in the rear! I have a Nisson 3.5 with forward only and have found it very awkward to use. The end of last season I purchased a Mercury with forward and neutral and find it much easier to use.
