Forward Hatch
Mat
I need a forward hatch for my 84'27ft Hunter.Any advice, where I can find one or any upgrades new or used.
Jay Kent
I am not much help
as I, too, had the same issue. I had two marinas, my nephew on the internet with over 10 leads and my personal efforts with calls, conversations, etc. following up on leads. Never found one!! Problem is, as you probably all ready know, that the hatch is an unusual shape and size. I even looked into the possibility of cutting out for a larger one.....that was discouraged by everyone I talked to due to the way Hunter constructed the decking!! So, I removed mine and completely sealed all around it and re-seated all the screws. This still did not take care of the issue of the broken "locking plate" (which is molded plastic). I, now, use the washer on one side of what is left and use the thumb tightening head of the bolt on the other side. Water stays out and it works....but it is, definitely, not the solution that a new one would be. If you decide to pursue one further, let me know if you find TWO. I'll definitely be interested in hearing about your efforts, too. E-mail me directly at jwk@towerconnections.com Good Sailing-- JAY
F
Frank
http://www.pompanette.com/bomar
C
CaptJeff
Trapezoidal Hatch
Check out the Bomar website at www.pompanette.com for info on the N2092-10A Trapezoidal hatch, this is the closest to the Original Plastic Gray Industries hatch that was Model #207, If you are looking for Portlights or other Surplus hatches, Check out www.thriftymariner.com They carry all the discontinued and Surplus parts for the older Bomar Hatches and Portlights,
