Forward hatch hinges broken on Hunter P 42
Sep 14, 2004
198
Hunter 42 Deltaville VA
My 1997 Hunter 42 forward hatch hinges (3) broke recently. They appear to be plastic hinge pins. It is a Bomar hatch. Has anyone had this happen? I am considering drilling out the hinge pins and replacing them with stainless bolts. Has anyone tried that? Has anyone replaced the entire forward hatch? How awful was that?
Thanks.
Below is the deck view of the hinges on the rear of the front hatch:
2,050
If, after talking with Bomar, you decide to fix them yourself,
you might consider stainless steel roll pins in stead of plastic replacement pins.
5,931
Ours have never broken. They appear to be aluminum components. No suggestions here.
Rick D
Jun 14, 2008
7,185
I'm sure you can find replacement stock that you can cut to fit through McMaster-Carr. This link is to just an example. There may be better choices. McMaster-Carr
