We have a '94 23.5. There is a compartment (I'm having a brain cramp and can't think of the right name for this) forward that is filled with flotation foam. There is water in this compartment that has seeped through the bulkhead and is leaking into the bilge area. I'd like to provide a means of drainage into the bilge- and hopefully save the plywood bulkhead from rotting out. Is there a reason not to drill a scupper hole on either side of the bulkhead and allow the water to drain freely into the bilge?Thanks Jim
