Forward Chainplates - Decks Soft
3
Oday 27 Wickford
So the decks are soft around my forward chainplates. The chainplates have a chain inside the cabin which reinforces them more down to the cabin deck or bunk. My questions is this.
I am thinking of using a grease fitting or 2 to inject epoxy into the deck in these areas. They are fairly dry but have moisture in a few areas which I will try and dry with some acetone before injecting. I know this is not ideal but I don't want to rip the deck off on either side in these areas due to time constraints and money. I know the correct way is to recore but I want to know if anyone has ever heard of a forward or aft lower shroud on these boats pulling through the deck because they were soft? While not ideal, I want to know if my method will be relatively safe?
Thanks.
Aug 20, 2010
1,399
Oday 27 Oak Orchard
Drying these buggers out is a lesson in frustration. My 27 had been covered and heated for 9 months and the core could still be squeezed and water ran in a stream from my hand. Balsa is like a sponge. On the plus side the previous owner was sailing this boat with shot core and loose lowers and the mast stayed upright.
Oct 10, 2009
1,062
Catalina 27 3657 Lake Monroe
I am not claiming this is the ideal solution, but I just firmed up the area around my stbd chainplate with polyurethane glue. It cures with water. I plan on trying this for one year and assessing it to decide whether it is a viable solution for other soft spots.
Jan 27, 2008
3,086
ODay 35 Beaufort, NC
Wouldn't bet my life on it
The bigger problem is that the chainplates are exposed to salt water in an oxygen deprived environment. This makes the stainless prone to stress corrosion.
