So the decks are soft around my forward chainplates. The chainplates have a chain inside the cabin which reinforces them more down to the cabin deck or bunk. My questions is this.
I am thinking of using a grease fitting or 2 to inject epoxy into the deck in these areas. They are fairly dry but have moisture in a few areas which I will try and dry with some acetone before injecting. I know this is not ideal but I don't want to rip the deck off on either side in these areas due to time constraints and money. I know the correct way is to recore but I want to know if anyone has ever heard of a forward or aft lower shroud on these boats pulling through the deck because they were soft? While not ideal, I want to know if my method will be relatively safe?
Thanks.
Thanks.
