C
crazy dave condon
Sometimes we run into things that you folks should be aware of. ON the 26 under the V Berth, I strongly suggest that you drill a hole in it near the hull to allow any water to escape; otherwise it will collect and cause that panel or bulkhead to rot as the water has no place to escape. In this situation, The hose from the anchor locker was the culprit causing the leak with water standing in the forward bulkhead for a long time. If you hear water thrashing about, then you will know what I mean. You have to have a drain hole in that panel. Like anything, it can be fixed but we are going to have to remove the bulkhead entirely and put an new one in its place.
