Forward Berth
L
Lee Boyle
I need suggestions on how to fix the squeaky forward berth. My wife and I spend alot of nights on our '85 Catalina 36. But with every movement the boards under the mattress squeak very loudly. Has anyone figured out how to silence the noise?
Tim R.
May 27, 2004
3,626
Yeah. Do it on deck instead!
:naughty:
I would say remove all the plywood and then rebed with some 101.
Jun 3, 2004
143
Hunter 33 Santa Barbara
Squeaky forward birth
I have a similar situation in my hunter - but the squeaks come from the dock lines. Could that be your problem (assuming you are referring to sleeping aboard at the dock)
Michael
Oct 2, 2008
3,814
Pearson/ 530 Strafford, NH
Hi Lee,
If you have a cover for the storage under the V-berth like my Catalina 30, try silicone spray or a roll of foam insulation with the sticky tape on one side. The wood cover on fiberglass can make for a restless night.
All U Get
Sep 24, 1999
1,511
Hunter H46LE Sausalito
there's a product called AGS Stick Lubricant...
...carried in hardware stores that's made specifically for the squeeks.
Ross? Who's Ross?
Ross
Jun 15, 2004
14,693
Re: there's a product called AGS Stick Lubricant...
I never heard of him.
Do you keep anything under the boards? No? fasten them down with screws.
Jun 2, 2004
1,438
Oday 25 pittsburgh
with all respect, I am thinking that the boards
are thin and have alot of deflection.
Beef up the boards and spend the lubricant money on the motor/ engine.
Boards that deflect move, the friction and even internal movement within the board makes noise. Beat the noise, beef up the boards...
sincerely
r.w.landau
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
Ditto what Ross and RW said. Boards that move, often squeak. Boards that don't flex or move don't make noise. :)
Benny
Sep 27, 2008
1,149
Hunter 320 Tampa, FL
Replace the wood with a thicker piece, bead with silicon sealer, and screw down. That should quiet the squeek down so you may hear the halyard slap.
