Forum question not a boat question
998
Hunter 38 Whitehall MI
With the update that was just pushed out this week something has happened and the site no longer works on my iPad. iPhone is OK.
Buttons don't work, can't log in.
Please fix these glitches
Squidd
Sep 26, 2011
890
AMF Alcort Paceship PY26 Washburn Wi. Apostle Islands
Sounds like the problem is in the pad...not the program...
Try dunking your cookies in milk...
Apr 11, 2010
998
Ipad works fine on all other apps,so its not the pad!
Was fine before the December 6 update which would seem to point to it as the problem.
One minute fine next minute not
marian
May 21, 2010
47
beneteau beneteau 351 Penetanguishene
I read yuor post from my ipad, now will press sent to see if my ipad works.
Dec 2, 1999
15,184
I have had similar things happen on my tablet. It may be one of YOUR settings that is causing it. I have no experience with Ipad so that is the extent of my help.
Apr 11, 2010
998
Just for clarification sake.
If I go to hunterowners.com and log in things are fine.
If I use the ipad app to try to get in that is when things don't work.
Feb 20, 2011
8,062
Aha! (Sent from my iPad 2 without using the app.) ;)
txjim
Sep 4, 2007
154
Hunter 170 Grapevine Lake, TX
This happened on Android devices as well, we had 3 updates within the last week or so. The first two required the user to go into the app manager and clear data and cache before the app would start. The final update seems to work.
Phil Herring
Alien
Mar 25, 1997
4,924
- - Bainbridge Island
I just installed the new ipad update. The first time I tried to use the app I couldn't even connect to it, but after an ipad reboot it worked perfectly.
What you're describing sounds to me like a local issue. I would reboot the ipad and if that doesn't help, delete then re-install the app.
I have asked Apple to suspend system updates until after I'm dead, but no word back yet.
Apr 11, 2010
998
Too funny on the apple comment but I'd agree since I had already rebooted 3 times and uninstalled and reinstalled the app twice before I posted.
So that didn't work.
