Tech Data on forestay strength and stretch
Y'know, guys, I think poor ol' Debra is starting to wish she never asked this question! And, all I can say is, well, I was pretty darn close to the length granting that maybe I wasn't dealing with a perfect right triangle. Great advice, too, on trimming to fit and using Sta-loks. Here's some tech data, Debra, on turnbuckles, wire size strengths and stretch.On turnbuckles, for standard, open-body bronze or ordinary stainless steel turnbuckles, the screw diamter should be twice the diameter of the rigging wire. The opening between the turnbuckle jaws should be twice the diameter of the rigging wire. The clevis pints should be twice the diameter of the rigging wire and always insert toggles between turnbuckle and chainplate and between mast tang and shroud eye.Type 302/304 commercial grade wirte wire should be used since Type 316 stainless steel wire, recommended for tropical use because of its increased resistance to corrosion, is approximately 15 percent weaker. This also uses 1x19 stainless steel wire as as the reference. Breaking strength of 5/16" wire is 12,500 pounds and 3/8" is 17,600 pounds.About stretch; two types, construction stretch in wire is permanent and results from the strands settling into place when the first load is applied. Elastic stretch is temporary, allowing the wire to return to its original length when the load is removed.The greater the number of strands in wire, the more elasticity it will have.The elastic stretch of a stainless steel wire increases in reough linear proportion to the load, up to about half the wire's breaking strength. Thus, stretch is a good indication of load. The following convenient metric formula will give acceptable results with 1x19 stainless steel wire: Load in Kilograms = (stretch in centimeters x breaking strength in kilograms) divided by total length of stretched wire in meters. (Hey! I'm sorry; they figured this in metrics and requires some conversion; I didn't invent this!!)Therefore, when a 10-meter (33 foot) wire of any thickness is loaded to half its breaking strength, it will stretch 5cm, or about 2 inches.Typically, a load of 25 percent of the breaking strength reprsents a moderate rig strain on average. So, in practical terms, a 50' length of 5/16" 1x19 stainless steel wire will stretch approximately 1.5 total inches. A 25 percent load in this case would be 3,125 pounds of load on the forestay.Henry was also very right about the deteriorating steel I-beam beneath your compression post and located in the bilge area. If you have this problem, let me know; I think I have a pretty good solution for it that I used on my boat.Steve also had a good idea; call a professional rigger and let him worry about the math!!
