so cal rigging
If you're doing it yourself, you will save a bunch of money by calling:Bay Sailing West, 2102 S. Wright St., Santa Ana. 714 557-1123.Get the specs from the C30 website, or remove a few pieces at a time and take them in to be matched. Use your halyards for support, but the mast is pretty stable when there is no sail attached.I replaced lowers first. Then uppers. Then backstay and forestay. Turnaround time is pretty quick from the shop so it doesn't take too long to do it this way, and you save so much money it's ridiculous. Take your turnbuckles and toggles in for inspection also. The most expensive thing is replacing the hardware, not the wire. Hopefully you won't have to replace too much of it.
