I am replacing a totally inadequate and I believe unsafe raw water strainer that came fitted in my boat when new. The engine is a Yanmar 3YM30. After some legwork, I decided on a Forespar MF 810 strainer. That strainer has 2 - 1 ½” ports for the inlet and outlet. I acquired 2 - Marelon (910063) male to female reducers to go down to ¾”. I also purchased a Marelon (905007) ¾” male to barb tailpiece to connect the outlet hose and a Marelon (901001) ¾” male to barb elbow for the inlet hose.
I put 2 – 3 wraps of Teflon tape on all the fittings. I installed the 2 reducers, first hand tightened and then 1 – 2 turns with a crescent wrench to what I felt was a good torque. I similarly installed the elbow except had to use lock joints rather than a wrench to tighten. All of these 3 seemed to have made a good solid tight mechanical joint. Then it came to the elbow. I threaded it into the reducer and found it very sloppy. I easily hand turned the fitting all the way into the reducer, with little resistance. It only stopped when the 90 deg barb butted up against the reducer and physically couldn’t turn any further. I had to back the elbow out a few turns so that I could fit 2 - ABA SS clamps on the hose. In that position, the elbow could easily be swung back and forth with one finger.
Being an optimist, I cracked open the thru hull and within seconds of the water reaching the strainer, I had sea water leaking out the inlet (elbow) fitting. I removed all the fittings, cleaned off the Teflon tape and replaced it with Permatex pipe thread sealant with Teflon. After allowing 72 hours for the Permatex to cure, the results were identical: 3 solid fittings and 1 very sloppy and leaking elbow.
So I researched the Internet some more and found a Forespar document that states: “Marelon plumbing fittings have NPT parallel threads. The threads can be sealed with Teflon tape or plumber’s dope.”
Well I have news for them regarding the latter. So I have a number of questions:
1. What the heck are NPT parallel threads? I thought the “T” in NPT stood for tapered and parallel threads were NPS?
2. I though you used Teflon tape on tapered threads vice parallel threads?
3. If Marelon plumbing fittings are all the same, why was I able to torque 3 of the 4 fittings but not the elbow?
4. How can I make the 4th fitting physically solid and leak proof? Could I or should I use 3m 5200 or West System 2 part epoxy?
A plumber I am not. Any advice would be appreciated.
Thanks.
Len
Thanks.
Len
