Last weekend the foresail halyard failed when it tore on the U-shaped mast appendage. I have drawn a rough picture of the rigging to better explain the failure. It is easy to see how the halyard could wear and break. There is a timely artical in this months Sail mag. on how to rerig the halyard so I am going to give it a try this weekend. The question is for those that have similar rigs. It looks like a pulley-block attached to the U-appendage would make a better bend than having the halyard run through the U. Has anyone done this and is it a good idea? Second, is it required to run through the U-appendage at all? Just raise the jib with the halyard from the masthead. Comments appreciated.
