Force Ten Help
Ron
I've had a Force Ten 3 burner w/oven and broiler stove for about five years. The electronic sparker has quit working and I'm sure it is the battery that has finally died. Problem is, I can't find the battery??? Does any know where the thing is located?? Thanks in advance... Ron
Bob Howie
Force 10 info
Try giving them a call at (604) 522-0233 or email, badams@idmail.com or website, www.force10.com. That should make it quick and easy.
John C. Baumgartner
no battery
Ron, If it is like an outside grill it use pezoelectric effect and uses no battery, a button is used to apply a pressure to a cristal that converts that pressure to a voltage that "jumps" a gap, that creates the spark. Sometime the cyristal get broken or "wears" out. replacement is a snap
Ron
John C
Hmmmm...... The reason I thought it had a battery is that if you hold the button in it will continue to spark (when working). You don't have to keep pushing it to make it spark again??? What do you think??? Ron
Tony
Battery
My force ten battery for the igniter is on the lower right front below the hinge mount it is a double A i think and the last time mine did not work, i took the battery out, cleaned the ends and put it back. also it can get loose from vibes etc Happy Broiling
W
wilmawindy
Force 10 ignition
On most of their galley ranges, the double A battery is located on the right hand stove side, bottom, front, inner corner. directly behind the model and serial #. If your unit is the 2 burner drop in type, it most likely does not have a battery and has the push piezo type ignition similar to a home grill. if this does not help, write force 10 @ sales@force10.com wilma
Ron
Tony and Wilma
Thanks.... That is what I needed to know. I will broil a couple of steaks and email them out to you. Much appreciated... A Hungry Ron/KA5HZV
