Force 10 BBQ-brass orifice
Rodd
Pearson 424 East Hampton,NY
Looking for the brass orifice that goes into the regulator on a large Force 10 propane grill. I bought a new regulator but it doesn't have the orifice! No longer available from Camco (Kuuma) in NC.
Thanks!
Rod
Jun 6, 2006
6,990
The grill should not have a "regulator". The regulator goes immediately down stream from the propane tank to reduce the pressure. the grill has a control valve that "regulates" the amount of regulated low pressure gas that gets introduced to the burners. Kinda like a throttle. I believe they call it a control valve.
Perhaps you are searching for the wrong item.
Rodd
hi Bill-
Thanks for the reply- no the propane tank connects directly to this regulator without any intermediate regulator- the high pressure connects right to the base of this regulator. It has a round black plastic top that you dial to low, med, hi, off. Inside this regulator is the brass orifice I'm looking for.!
Any ideas?
Rodd
Rodd
Thanks Steve! Sure enough Sure Marine had it for sure!!! This board rocks!!
Rodd
