Selden ...
AFAIK Selden no longer makes the kits to retro-fit mast furling. We just intalled one of the last "old stock" kits on a C&C 30. CDI has a "behind the mast" main furling system that uses parts from their jib furling system. I've also seen other jib furlers mounted behind masts to furl mainsails.For retro-fitting mainsail furling, in-boom systems are a better bet. Selden, Pro-Furl, and Forespar all offer in-boom furling systems.The biggest problem with adding in-mast furling to an existing mast is weight. The mast section is designed to handle all the rigging loads, when the roller furling is added, the extrusions add weight and strength that is not needed. A mast designed for roller furling will be heavier than a non-furling mast, but not nearly as heavy as a mast that has had roller furling added.
