I did the same on my 3GM that was prone to cake up. I used a diluted MA. Never had a problem after that (but was also more careful to avoid long idling or low RPM powering for extended periods.)I used to do an annual acid flush on my raw water cooled A4 wth muriatic acid. You wat to follow this up wth a neutralizer and plenty of fresh water.
It has been a few years but I think I recall mixing it 50/50. Always pour the acid into the water; not the other way around.Tim R. Did you "cut" the M.Acid, or put thru at 100%??
The acid is not left in the engine long enough to cause any long term issues. And you always neutralize it when done. The A4 in my '77 Pearson had this performed on it every season and it is still running strong.ummmm muriatic is typically only 35% strength Hydrochloric. Muriatic will dissolve any base metal of the engine internals exposed and will also totally destroy any protective formation of ferrous rust (blue/blact rust). Using muriatic/hydrochloric acid in a cast iron engine is a VERY bad idea - it can also lead to 'slab rust' in the exhaust manifold, etc.
