Follow up on compressor won't start
Tim
I removed the entire unit, took apart the module, cleaned it up, and re-installed it. One thing I noticed was the previous owner had used a very tiny guage wire to the compressor, so I pulled new larger guage wire back to the control panel. After reconnecting the unit it started no problem. The compressor came on within a few seconds. I let it run for a while but am still getting no cooling in the ice box. Any thoughts? Tim I have an Adler-Barbour model DCM-12 on my 1988 30 Catalina. When I turn the unit on, the fan comes on but I don't hear the compressor start (no vibration either). I've turned the thermostat up and down and left it running for 15-20 minutes but I still get no cooling. I've even jumped out the thermostat but no such luck. Any thoughts? PS, if the unit is low on freon, can it be re-charged?
Bill Thomas
compressor will not start
The thin gauge wire was causing the compressor not to start. If it is running and not cooling, it will need to be serviced by a refrigeration tech.
