Andy, have you heard of this prop?
Andy, this is common when it comes to finding the right prop. If I didn't have a good prop already, this might be something you want to try out: The KIWIPROP. This is a Newseeland product, fairly priced, lightweight, made from superstong Zytel, for sailboat engines up to 50hp. Great customer support, and VERY knowledgable people. They will ask you all the difficult questions about your boat, but once you are there, they might have the prop for you: A new Zytel-design, exchangable blades (individually) but feathering. But if you snag a line, they are elastic and usually there is no damage, but if, to change a blade would set you back $100. The pitch is adjustable, even in the water. Zytel is a plastic material, that, for example, Porsche uses for some engine parts. Try this address: kiwiprops.co.nz. Good luck, Lee
