Why do we purchase roller furling for the jib to begin with? Just to get away from hanked on sails; or to just get away from having to reserve room below deck for sail storage?
Roller furling w/o functional roller reefing is what the waste of money is in my view. The whole point of roller furling/reefing is that you do not have to carry a full inventory of sails to go cruising; or even racing. One head sail can be used through a range of wind strengths IF the thing can be reefed down and still perform adequately. Without a foam luff built in, it simply cannot do that. If you want a heavy, expensive, high windage foil on which to hoist a head sail with its foot two feet above the deck (loss of sail area), and all you can do with it is roll it out all the way, or roll it in all the way, then I'm stumped. Why would anybody do that? What's the deal?
The "deal" is simple. A single headsail to cover all "reasonable" conditions makes little sense for many reasons, even if you have "foam luffs" and "reefer furling." (Like my ProFurl).
I admittedly sail in an area known for its summer high winds, but it's pretty mellow here in the winter unless a front has just passed, which makes for N instead of W winds, same strength.
But I sure enjoy using the furler instead of backwinding the jib and rolling it up and putting it in bag.
That's why.
Anyway, I believe that folks who sail with 155s are, dare I say this, plain crazy.
Besides having too big a sail if the wind pipes up, which is what they're WHISTLING for to begin with
), finding the right balance between a sail cloth weight and jib sheet sizes and weights boggles my mind. I'm sure, however, that some wag here will have solved that problem and will report here forthwith.
If you have a masthead rigged sloop, your drive is in the jib. If you have a B&R rig, stop reading right now, 'cuz the rest of this doesn't apply to you.
A roller furling/reefing system makes sailing easier, the reason they invented them. Safer, too.
But trying to find ONE sail to fit all conditions is lunacy. Really. Why should it be any different than when we carried multiple jibs for different wind conditions, 'cept that the furling can help, but only help a small bit.
I sail with two jibs. 85% for heavy summer winds (20-40), winter 110 (0-20). I race with the 110.
You might be interested in this, from right here on this forum:
A very illuminating and interesting discussion on co.com for those of you who might be in the market for a new jib.
http://forums.catalina.sailboatowners.com/showthread.php?t=155362
Please read all three pages. Enjoy.
