Work on rule #1 instead.
Rule #1 - Keep the water out of the boat.Short of filling half of your interior with foam there's not much you can do to make a lead keeled boat float when full of water. Instead, focus on rule #1. Nothing will help if you have a catastrophic hull failure, but, many boats sink with relatively small holes. Many sink without any hull failure at all, just from some other reason for too much water coming aboard.Look at the GPH capacity of your bilge pump. Considering the rate of flooding through a failed hull fitting, do you have the pumping capacity to handle it? You should have more than enough pumping capacity to handle a complete failure of your largest hull penetration. Adding a couple extra 500 GPH pumps is cheap insurance. And a heck of a lot easier than trying to fill a keelboat with foam.
