Foam Backed Vinyl Hull Liner
raysco
Mar 26, 2007
6
- - norfolk,va
I have a 2002 306 and had a leak (still looking for it) in the stern cabin berth. I want to replace the vinyl hull liner on the port side. Does anyone know where I can find matching vinyl?
Dec 2, 1999
15,184
Ray:
The first thing I would suggest is to contact Hunter Marine. They may have this type of material in stock or know where you can get some matching material. They are very helpful in this area.
If you do not need to match anything, Sailrite sells several products that you may be interested in.
http://www.sailrite.com/
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
Rub Rail
Try checking the rub rail where the top and bottom halfs are bolted together,I had a leak at the rear stern ladder section and when motoring it would dig into the water line more and leak,I had to remove the rear cabin bulk head to find and also had a leak on the port or starboard side of the hull.
Nick
Jack
Jan 30, 2008
121
Hunter 33 -
Re: Rub Rail
Seadaddler,
funny thing, we had a leak around the same place, where the deck and hull were joined, glued with 5200 and bolted, port stern area. after we went through countless hours of trying to figure out where the water was getting in we finally figured it out. We contacted hunter about the repair but they said it was not a hull warranty issue but rather a seal issue which isn't covered under warranty. Total BS...
Just wondering if you fixed this yourself or did hunter cover it?
J&R
