The "gardener did it with a rake".Under the bed in the Port aft cabin there is a Diesel tank and in the starboard aft cabin is the aft a/c unit.....
I don't have a watermaker I actually had to move my compass because it was to close to that forward battery. Every time I used an electric winch, my autopilot did a "crazy ivan"there is a Water Maker under the seat under the TV....
If you have spaces under some of the teak and holly sole pieces, check there. I put mine under the sole aft of the V-berth in the forward cabin. Keeps it out of the way, dry, on or near the center line and generally away from iron objects. - UNLESS - I once set a big bag of tools on top of the cabin sole above my newly re-positioned fluxgate. I had just gone through a bridge (I never use it when in tight maneuvering space) and reset the autopilot to hold heading to go below for a second. When I did that it did a 90 degree turn.I don't have a watermaker I actually had to move my compass because it was to close to that forward battery. Every time I used an electric winch, my autopilot did a "crazy ivan"
I think that is the greatest suggestion I've seen on here!Can I humbly suggest that on a boat that you own or regularly sail on, that there should be NO AREA of the boat that you are not familiar with, that you know were everything is, where all thru hulls are, where every major bit of plumbing is, there is no component or 'box' that is of unknown function?
I think that is what the OP is doing, by asking.NO AREA of the boat that you are not familiar with,
I believe I should give credit to @kloudie1 on the Fluxgate "detector".Someone offered me a very clever idea on how to find it.
What?!!letting the AutoPilot manage the helm tracking straight and true.
Well maybe. But 99% of these questions come from a casual look after it fails.I think that is what the OP is doing, by asking.![]()
And granny smith apples!It doesn't just take Iron to mess it up, bulk of liquids do too.
Cans... metal, right? I don't think it has to be "iron".Believe or not, it was near where the Admiral had just stowed canned beverages. It doesn't just take Iron to mess it up, bulk of liquids do too.
