have a Macgregor 22 with a tohatsu 6hp sailpro that has a flushing port. boat is in a slip. With the motor bracket in the up position the impeller water intake is below water, so when I flush the motor, I have to tilt it, any problem with this? It does run while tilted, just seems unconventional and not sure if the engine oil gets picked up. I like to run the carb empty while flushing, so not sure if this can be achieved if tilted.
