OK, for all you fluid engineers out there...
Assume there is some internal pressure in the tanks. My assumption is that the weight of the fluid has a effect on the way the fluid is pushed out of the container
1. Say one has tandem container. Say that both containers are full. If both containers are connected to a consumption source, would it be safe to assume that the fluid form both containers are drawn equally?
2. Say one has tandem containers, but one container is 50% and the other 100%. Would fluid dynamics draw from the full full container until both containers are of equal pressure or will they both be drawn equally until one container is empty?
3. Would the full container assist by feeding into the partially filled container to equal the internal pressure?
This should be a good discussion.
