Ok, I need some help. My 1989 Hunter 28 has a cockpit floor panel behind the binnacle which was originally made of fiberglass and cored with plywood. This panel has failed and I am replacing it with a new solid wood panel made of teak and birch. I have completed building the new panel and it is ready for finishing.
I've seen products like Smith's CPES and SYSTEMThree Clear Penetrating Epoxy which all look to be good options for sealing the panel before the final varnish coats. The panel will be under our Bimini and can be removed for the winter and stored inside but, it will be exposed to sunlight and of course take some moderate foot traffic (I don't live aboard but try to be on the boat most weekends)
Does anybody have any experience with the above sealers or any other products. Is one really any better than the other or could I just use regular West System epoxy as the seal coat (which I have on hand).? Should I plan to put a clear coat varnish over the epoxy? or just more coats of epoxy?
Any and all comments are welcome,
Thanks,
Victor
Thanks,
Victor
