Flooding issues with Tohatsu 8 HP 2-stroke
Apr 11, 2020
795
MacGregor 26s Scott's Landing, Grapevine TX
Update:
Adding a petcock to my fuel line seems to have done the trick. Still on my agenda is replacement of fuel lines and fuel pump diaphragms.
Apr 11, 2020
795
Update and final resolution. Spoiler Alert - replaced carb.
Fuel leak at fuel pump (apparently - could have been fuel line at pump) and chronic flooding led to the following:
-Replacement of fuel pump diaphragms and gaskets
-Replacement of carb gaskets, float valve, rubber seals and caps (all the cheap and easy stuff). These just because it was easy and I had the carb off anyway.
-Soaking carb in carb cleaner
-Replacement of fuel lines
Result - motor would start and run, but only with choke half on and throttle half up. Anything less on either and motor would die.
Opinion of a local shop was that I had not cleaned the carb properly.
Having spent a good deal of time, I decided to cut my losses and just buy a new carb. $188 seemed a bargain based on labor estimates at one local shop.
Outcome - new carb solved all my problems. Starts easy, no flooding, idles nicely.
Takeaway - carbs can be finicky if you don't know what you are doing.
Anyone need a parts-only carb for a Tohatsu M8B? Cheap!
  • Helpful
Likes: FastOlson
