Floating line
RAD88
Dec 15, 2008
163
Hunter 30 Glen Cove, NY
I am looking for a UV resistant floating line for my dinghy. Not polypropolene !!! Any ideas___
Benny
Sep 27, 2008
1,149
Hunter 320 Tampa, FL
Polyropolene lines are quite inexpensive and could be replaced frequently before UV degradation sets in. None of the sturdy polyester lines have good floating qualities. If for towing a dingui, you may consider adding a few floats at intervals to a polyester line.
Jan 1, 2009
371
Atlantic 42 Honolulu
You could use dyneema (they sell some here but you have to fight your way through their strange system to get a quote). It is strong, floats and has good UV resistance. It is really wonderful stuff and is being used commercially to replace wire for towing, trawling and mooring oil rigs. It's probably just about ideal as a dink painter. But, you could buy a whole lot of poly-pro for the same money. Keep in mind, not all poly-pro is the same. There are some poly pro lines that have a decent hand and hold knots adequately. The best poly-pro (like the stuff they call "Silver Line" down under) is actually pretty decent rope.
--Tom.
Nov 22, 2008
3,562
Endeavour 32 Portland, Maine
The stuff I bought right here on SBO is very nice. I've forgotten the name but I'm sure they will tell you.
