Mike Linstrom
I need to replace the float switches on my '85 H34 and I was hoping to get some input. There is a switch for the main bilge pump and another for the forward pump which drains the shower. Neither appears to work although I know the shower switch and pump worked recently. Both have Rule a matic switches and the shower pump is a Rule 800. I can't read anything on the main bilge pump. The main bilge pump also operates manually from a switch on the DC panel and it is working. I haven't seen any way to do this with the shower pump. I'm not an electrician but I have wired "dry" systems like stereos, house fans, 12V batteries, etc. How clean and dry does this thing have to be to do the work? What do I need to know about the types of connectors to use? I assume tape is not a good idea. Can I splice into the wiring where it comes into the bilge or do I have to run it all the way to the battery and panel? Any help at all is much appreciated.
