Flexible Water Tanks
Doug J
May 2, 2005
1,192
Hunter 26 Oceanside, CA
Can someone with experience, good or bad, with these tanks give their opinion of them? Are they reliable? Are they prone to leak after a while?
They are made by Plastimo.
Rick D
Jun 14, 2008
7,206
I have a 15 gallon one I use on my dinghy to refill the water tanks on my boat during extended stays in Catalina. It works just fine. Having said that, I have used two in other boats, but they were Nauta which is more expensive but, I think, more durable. I used them as a primary and reserve for years and found them to be flawless. Plastimo may be fine in that application too, I just do not have experience with it. BTW, I am considering eventually adding a Nauta fuel tank as an auxiliary.
Dec 2, 1997
9,011
- - LIttle Rock
Bladder tanks are ok for water holding (but not a good choice for waste holding), but I'd go with a Nauta tank...they're a bit higher quality than Plastimo. Average lifespan is only about 15 years...IF the tank is installed to prevent chafe and maintained.
For about the same price or even less, a good quality rigid plastic tank will last as long as the boat if it's maintained. Check the Ronco Plastics catalog...they make top quality plastic water and waste tanks for a very reasonable price (price is even better if you order it through the online store on this site) and have more than 400 shapes and sizes, including over 100 non-rectangular...and they install fittings in the sizes and locations specified by the customer when they make the tank. Ronco Plastics
Jul 29, 2009
71
Irwin 37 c.c. Cutter indian rocks beach, fl.
My boat had 2 flexible waste tanks, one is still working fine and no leaks when pumped full and the other one split at a seam so I removed it. Both were original and are 36 years old. All I know is they were made in France. I could not get a plastic one into the space provided and I have seen plastic ones crack for no apparent reason.
Dec 2, 1999
15,184
Like Peggie said, you need to be sure that the tank does not chafe/abrasion from rubbing back/forth when you are tacking. Most of the time the lockers where these tanks are mounted are on the raw hull.
These tanks are usually expensive (14 gal cost $210 @ Defender) and considering you could be replacing again in a few years if NOT properly installed you may be better off with a poly tank.
